ok had an unusual issue..when I first got the DD1 I checked the radio, everything flat...track 1 my number was 22, track 2 as soon as i hit volume 23 the signal light and distortion comes on so I assume my number to be "22"....I showed this several times to different ppl how it worked always came up the same
I was out going through some things and wanted to redue everything and show someone how it works...I set the radio back to flat on everything,hooked the DD1 up, played track 1 and no matter what it wouldnt get a signal...turned it off and let it sit about 10 minutes...went back out and it now gets a signal and both track 1 and 2 distort at 29...how did my number change to "28"
and witht the 360.2, which track to play when setting the gains for the front rear and sub on tthe 360.2 unit itself
