need help on a amp
cgomez90
The AQ 2200 should work just fine.................but there are a lot good amps out there, so do some investigation....I love AQ............
  • Minivanfromhell -- Proud Member of Shut It Down Boyz & GEORGIA CAR AUDIO
Pioneer DEH-3400-UB
Vega 65 cs & 1" tweets & T3 4" coax in Front
1- Dual 300 with an AQ sticker
2-AQ sdc2.5 12's
1- AQ 1200D.1
Monster Cable RCA's
Monster Cable 4-awg
Custom 4 th order box ( by DBC )
Crescendo FT1's in rear- 1/0 Big Three
Opti Blue top in back for Mono Amp
Stinger Power dis. block
125 amp breaker at front batt.
Stock Alt.
I was thinking a dd m2b
same exact board, just better/upgraded internal components, for like twice the price almost.
edit: and same thing with the m1b or whatever you recommended to someone else in another thread. same thing as an aq 1200, just upgraded components for way more money
Edited by Kranny
a (NICE 2500 watt D CLASS) Two Chanel amp, that is at least (1 omh stable).. would work for what you trying to get done! but note at that low of omh's you might want to add you a secondary battery, and upgrade your alternator if its in your budget to do? that would maximize the true performance of your system.. many might say this would double the performance!! hope that helps you out on this amp matter..
  • Who's Online   2 Members, 0 Anonymous, 1658 Guests (See full list)
