Hey your looking at a SAME AS Rd audio 5750.1 or ATOMIC 5000.1 amp this particular amp is the same as those mentioned above their the same in every single way except this amp has no logo the amp is like new except one single flaw.
the amp was used at burps at 0.5 ohms with a single amp i know im dumb and we blew the power supply output transformers ( FETS). They are probably IRFP064N -- that is generally what FET is used in the power supply on the TO-247 case. chris at db-r can definately fixed it i got an quoted at audiotekx 150 to fix it you can repair it locally if you know about a good shop the repair locally will be less than 100 bucks.
They sell for over $2000 retail and around $1500 at competitor cost! My price is $750 BUT this ones blown im asking 500 the 250 left will be for the repair cost.
specs
* Digital mono block amplifier
* Dual MOS-FET power supplies
* Efficiency over 86%
* RMS power handling---1500w @ 4 ohms @14.4V
* RMS power handling---3000w @ 2 ohms @14.4V
* RMS power handling---5000w @ 1 ohms @14.4V
* Signal-to-noise ratio 90dB
* Phase shift 0-180 degree
* subsonic filter: 10-60Hz
* lowpass filter: 35-300Hz
* Input sensitivity: 200mV -6V
* Bass remote controller with telephone wire & click volume & blue LED
* 3 way protection: over voltage, speaker short & thermal overload
* Total harmonic distortion:< 0.1%
* Continuously variable 0 – 18dB Bass Boost
* Built - in variable 0 – 18dB per octave x’over
* Power Consumption< 490A
* Size: 24.50” x 10.60” x 2.60”
they are bridgeable or linkable it was very dumb of myself run this with only one battery and stock alt everysingle person that really knows these amps recommend at least 2-3 extra batts with a good alt and u can run it all the way to 0.35 ohms at burps.
im located in chicago ill 60623 local picks ups always welcome pictures with name are welcome pm me for those kinds of pics, paypal ofcorse i will accept money orders only if the check has cleared i will ship, google check out too if you have problems with paypal,
this is a great offer.
PLZ dont post dump i will report post dumping to the admin WATCH THE RULEZ!!!
the internals pics are actual pics the parts i noted needs to be replaced you can fix it if you want but i suggest a profesional repair shop.
thanks
daily driving set up:
6 12 inch phoenix gold subwoofer
1 kicker kx2500.1 at 1 ohm ( the other one is waiting for the charging upgrades to get done)
2 optimas
pioneer 980bt
phoenix gold 8.0:4
diamond audio d9 mids with m3 tweeters and crossovers
polk audio coaxials in the back.
200 ft of knukonceptz wire
spl set up: if i decide to make it happen
2 re audio 12 inch sx with mt coils (for sale)
1 or 2 kx2500.1
This topic is now closed to further replies.
  • Who's Online   0 Members, 0 Anonymous, 2115 Guests (See full list)
