Hi I used to have a Ford explorer and I just sold it and got a 05 Chevy Trailblazer Lt. I stripped everything out of it and I plan to put it in my Trailblazer. Wiring everything in my explorer was a breeze,now I have to figure out this Trailblazers stuff. It has onstar and bose system. First thing I need to know if anyone can help me out. Do I absolutley need the $110 wiring harness? or can I get by with the $20 one? some guy was telling me that if I didnt get the expensive one that all check engine lights would turn on and stuff. Also the other question was about runninng the power wire. Am I going to have to drill a hole thru the firewall? I cannot see a good sized hole in it. If there are any Trailblazer owners please help me out. Thanks.
Yes u will have to buy the expensive harness I asked that same question when I had to purchase mines...and u can run ur power cable through the wire harness rubber on the driver side I was able to get 4 runs through it
2004 trailblazer
4 FI BTL 18s
(2) DC 10.0k
xs power d3100s
mechman 270
158.2 @41
The headliner won't do anything to the sunroof, but having 140+db will.
Mine is all fucked up, sounds like shit, but it works still :)
If your doing anything 145+ I'd would put at least a layer of SS, AT, or whatever you use.
wow now this just shows that smd isnt just any forum. We are a brother hood.
here let me put it in retard-onix for u aareehhhh duuuurrrrr ehhh got it now?
Sweet baby jesus the amount of quoting the quote above the quote in a quote is epic
How much roof flex do you have? Do your sun visors jump around?
I dnt have a sunroof but I would deaden the roof because trailblazers has only one stable structure support in the roof the other two headin to the rear is flimsy as a yard stick
2004 trailblazer
4 FI BTL 18s
(2) DC 10.0k
xs power d3100s
mechman 270
158.2 @41
Hey i have a Chevy Trailblazer and you have to buy the GMOS adapters depending on what model TB you have. You can buy the cheap Scoshe model if you want but i wouldnt recommend it not a very good quality product if you ask me.
2007 4.2L Chevy Trailblazer Crossfire Build
6 Crossfire xs v2 15s
3 Crossfire 8ks
4 Crossfire 6.5 Loudspeakers
2 Crossfire ST-1 Super Tweets
1 Pair of Rockford Fosgate T2 5.25 Components
1 Crossfire C5 800.2
1 Crossfire 400.2's
7 XS Power xp3000s
​6 C&D Batteries
3 Singer Alts
6 Runs of 1/0 OFC (Sky High and Welding Wire)
SMD VM-1
SMD OM-1
Pioneer AVH-p4800BS
Build Log
4th Order BL - http://www.stevemeadedesigns.com/board/topic/189896-4th-order-crossfire-trailblazer-buildlog/
Flat Wall BL - http://www.stevemeadedesigns.com/board/topic/198087-2007-42l-chevy-trailblazer-flat-wall-rebuild-build-log-4-crossfire-xsv2-15s-2-crossfire-8ks-xs-power-batts-singer-alts/
Scores
MECA - 159.2 @ 37hz
USACI - 161.2 @ 47hz
IASCA - 157.9 @ 47hz
  • Who's Online   0 Members, 0 Anonymous, 3041 Guests (See full list)
