Need Port help for RE SX 15
Hey I need help on what kind/size of port to use for 1-re sx 15. RE web site says 4 cubes @ 34hz. Is tube port or vent best?
I can build a box no problem but being a sealed box man when it comes to ported stuff Im clueless lol.
My measurements Are 17" wide x 42 long x 14 high. Sub facing up at 1 end.
Any help or advice will be greatly appreciated.
you will need your port facing on the same side as your sub and to tune to 34 hz u will need 3" wide port at 26" long and you will end up with 3.42ft^3 net internal volume of your box at the dimensions given.
and after woofer displacement it'll need to be 29" long if u go with 3" wide to tune to 34hz and your internal volume will then be 3.11 ft^3 you can also go with 2.75" wide at 24" long and get 3.39ft^3 internal net volume. hope this helps you deside.
if you want to go with aero ports to tune to 34hz you will need 3 4" dia. ports at 17" long that how long the kit is when you order them so no cutting involved. and your net internal volume would be 3.94 ft^3 which is closer to what your looking for and you would need to place those coming out of the side according to your dimensions given.
  • Who's Online   0 Members, 0 Anonymous, 423 Guests (See full list)
