i have a memphis mca3004 that is wired in with 3 mcd1000's yesterday i put power to just the 3004 and it powered on. today i wired everything up in the amp rack with a distribution block and the 3 100d's power on fine but the 3004 shows protection. sometimes it will light up green. but not very often. it is not hooked up in my car just hooked up on my test bench powered by a battery box/charger. tried hooking just the 3004 to the battery box and still protect. i was thinking ground issue but not sure.
2002 trail blazer ls
- Sundown Audio SA-8v.2 (6)
- Memphis Audio MClass 1000D (3)
- Memphis MClass 75x4 running Memphis componets
- Kinetik 2400 in rear
- Pioneer AVHP-4400
- box currently tuned to 34HZ but rebuild is in process
- Stinger RoadKill to be put in within the next 3 weeks
NEW BUILD IN PROGRESS:
-(8) SUNDOWN AUDIO SA8V2
- (2 SETS) SUNDOWN 6.5CS
- (1) SUNDOWN 125.4
- (2) SAZ2500
- (1) kINETIK 1400 IN FRONT
- (2) KINETIK 2400
- (2) RUNS OF KNU CONCEPTZ 0 GUAGE
- (2) BOXES STINGER ROADKILL PRO
- PIONEER DEH4400
LEFT TO DO:
- BUILD BOX
- ORDER 350AMP ALT FROM TENNEY ALTS
definitely would recheck your grounds sand them down a little bit more to make sure contact is really good... as long as you did cross any wires/arch anything during the install then the ground your using most likely seems like the issue
1 Fi Sp4 18
Crescendo 2k
selenium mids
audioque supertweets
Hifonics for mids and and highs
1/0 power and grounds
---> on the way singer alt and possibly another
2k depending how sub likes 1 2k
its not grounded to any metal. the amps are in the amp rack wired to a distribution block. with 4 guage then o guage ran out of the block. that 0 is hooked to battery clamps. from a battery charger. like you would hook to the battery of your car. nothing to sand.
- Pioneer AVHP-4400
- (1) SUNDOWN 125.4
- (2) SAZ2500
- (2) KINETIK 2400
- PIONEER DEH4400
LEFT TO DO:
- BUILD BOX
  • Who's Online   0 Members, 0 Anonymous, 988 Guests (See full list)
