Renault trafic SQL Build from Scotland ...
Next up was to change the look off the outside again decided to colour code the front bumper the bonnet air intake and the side repeaters so from this
to this
ending up with this
also added the chrome mirror caps and stainless steel roof bars
next up we upgraded the wheels to 18" from 16" and tyres went from 195 to 255/45x18 F1's
then next job was to get the seats leather trimmed so from this
the came back looking like this
right time to bring this up to date this this part off the build started May 2009 i'd had good results in Iasca and EMMA sq formats so it was time to play with the big boys so these were bought
this was to be a complete front to back DLS of Sweden Build
but there was no way of putting all these on the same back board from the previous install
so plans were drawn as this lot had to go into the roof too still need space for work
which turned in to this
and was hinged at the front to allow access to wiring etc
that'll do for now
then boards were made to fill in the stainless
then varnished to match then the fun off bolting up 8 amps and a processor cover
side panels were cut to fit 2 x sets off DLS 5" nobeliums for show days plus we had to move interior lights too
and on to the amps 36 holes drilled and bolted up with spacers ready to recieve the amps
i have some time so lets do some more next up is batteries and power distribution
kept the batteries in the same position as last build but doubled them to 4x yellow tops as i said this is getting more into high end SQ with extra bass when required
so
new battery box was constructed ignore the old mossfet amp and cabling this was just my temp daily system as the van is used every day for work and still needed some kinda tunes
stainless steel battery rack was welded up
then bolted in cabled secured and terminated with JL audio's finest battery clamps
next we needed to get power to the roof
plan was to keep the van build to a theme so for the power we needed to make a distribution centre and a plan was hatched we bought up
second hand burnt out amps and used the cases to cover all the fuses so the new bulkhead was made
then add a P/G DD10
and you add some spare amps and you end up with something that looks like this
closed
open
and powered
I have saw this van in person what a show piece ,Ian you should be very proud of your work it A1 :drink40:
cheers bud looking forward to putting up the next set off pics and then the front end build B)
