amp issue
honolulublue
i just came back from doing errands and i was pounding my rockford 1000 bdcp with lil kim keys to the city and it shut off. pulled over to have the car wash and still no sub. when i got home i re surfaced power both ends, ground to the amp (did not resurface ground to car) power fuse was still intact resurfaced and re crimped remote but when i turned on the power the thermal light would blink feintly once then nothing. the gain setting on my amp is set lower then half way up hertz to 37.
what di u do wrong?
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
well for one i did not read the bottom and thought it was four ohm per sub because of the jumper said 4 or one then realized they were two so my wiring came down to .5 ohm on a one ohm stable sub went to test it and thankfully the amp turned on but did not notice the crack in the power wire fuse until i tested to see if i fried my amp...due to panic good thing my gain was not up and i still had to go through deck to sub but still the draw was dangerous and cracked the fuse but, not break it...
i have ran the punch 1000 at .5 ohm b4 with no problem
pioneer DEH-P8400bh
XS Power D1200
Shuriken BT-100
audioque 120.4
2 audioque 2200d
big 3
479-418-3056
  • Who's Online   0 Members, 0 Anonymous, 1093 Guests (See full list)
