9blazer8 Posted April 6, 2012 Report Share Posted April 6, 2012 hi i recently got my truck on the road after replacing a trans and i hooked up my amps and everything was working well but today i turned the corner and my subs stopped working and my interior amp made a werid noise like something was touching together so i pulled over and nothing was touching but it still seemed like my rcas had some humming noise coming threw them even my subs where pulsating. so could it be my rcas? or should i just pull out my old wires and run new wires ? what do you guys think Quote Link to comment Share on other sites More sharing options...
ant the ninja Posted April 6, 2012 Report Share Posted April 6, 2012 Did you check your ground? Maybe when you took the corner something moved or pulled and it came loose? Just my .02 Quote 2002 Ford Explorer XLT Front Stage: Crescendo CCX 6.5's Rear Stage: ??? Two 15" Powerbass M154 Audiopipe AP15001d Pioneer DEH-P5100UB Link to comment Share on other sites More sharing options...
9blazer8 Posted April 7, 2012 Author Report Share Posted April 7, 2012 well i havent checked that but i just bought a new set of rcas and nothing its a werid humming noise like when you have rcas and remote and power all on one side but i dont im getting pretty upset about it im just about to rip out all my old wires and run new wires this weekend Quote Link to comment Share on other sites More sharing options...
ant the ninja Posted April 7, 2012 Report Share Posted April 7, 2012 (edited) Could be bad RCA's but I doubt it, just check your grounds, make sure its on bare metal and the connection is solid. If its not that, check everything for cuts or pinches. Also, unplug your rca's and see if the humming stops Edited April 7, 2012 by ant the ninja Quote 2002 Ford Explorer XLT Front Stage: Crescendo CCX 6.5's Rear Stage: ??? Two 15" Powerbass M154 Audiopipe AP15001d Pioneer DEH-P5100UB Link to comment Share on other sites More sharing options...
9blazer8 Posted April 7, 2012 Author Report Share Posted April 7, 2012 well its not the rcas i just bo ught a brand new pair and i get it threw out my truck even my interior amp im kinda lost ive never had something like this happen no wires are touching but im thinking it might be my head unit i have a brain for my indash so i think it might be that. Quote Link to comment Share on other sites More sharing options...
ant the ninja Posted April 7, 2012 Report Share Posted April 7, 2012 What do you mean you have a brain for your indash and interior amp? you have more than one amp? I need some more details. I'll bet you anything your ground came loose, doesn't seem like you want to check that though...ha Quote 2002 Ford Explorer XLT Front Stage: Crescendo CCX 6.5's Rear Stage: ??? Two 15" Powerbass M154 Audiopipe AP15001d Pioneer DEH-P5100UB Link to comment Share on other sites More sharing options...
9blazer8 Posted April 7, 2012 Author Report Share Posted April 7, 2012 well i made sure my ground isnt loose i could go and change it, and yes i have a brain for my headunit just for my rcas and other things. and i have a amp on my interiors and a amp on my subs. Quote Link to comment Share on other sites More sharing options...
95Burbancalldsnow Posted April 7, 2012 Report Share Posted April 7, 2012 Though I've felt like an idiot today trying to build my first box for subs I'm with the other guy(s) being that it worked fine until you replaced they tranny I would go through and double and triple check your engine frame and bodie grounds Quote Link to comment Share on other sites More sharing options...
Goblenator Posted April 7, 2012 Report Share Posted April 7, 2012 maybe your amp took a $hit on u Quote Link to comment Share on other sites More sharing options...
9blazer8 Posted April 7, 2012 Author Report Share Posted April 7, 2012 well its not the amp or amps they still work its to me it seems like the rcas are the problem but i just replaced them both. it sounds like a winding noise like something is touching but nothing is. and i replaced the tranny 2 weeks ago but thats a good guess since i did turn a corner and it did it. i have power just 1/4 of what it was and it has that noise im thinking about ripping the wiring out and replacing it. Quote Link to comment Share on other sites More sharing options...
