box calculator?
i been trying for like a hour it doesn't give port cuts. may be you can fill it out for me. with the info i give you
2009 bmw 5 series
Head Unit Stock
Amplifier-JL Audio JX 360/4
Processor- Audiocontrol LC6
It should give everything.. I can input it into the calc if you give me the exact dimentions you are using, any bracing how many port walls ect.. it's pretty simple man. I'll throw up an example if you want one. I'll even edit it some to help you understand a bit more
Check out my build log:
http://www.stevemead...60#entry1958353
Different folks have different strokes.
Uploaded with ImageShack.us
You want around 14-18 port area as a general rule of thumb, You want to make sure that your cubic volume is around what's recommended unless you know what your doing.. the level three was 1.5 cubic recommended. See if you can get it before I try it.. would rather you learn that me do it for you :) any questions lemme know.
yes i want to learn, this is what i have after 1.5 hours. now i print it it does not give port cuts. sa10box.png Uploaded with ImageShack.us
Notice how mine doesn't have it either? Put it in sketchup. Then measure out the 27.75 for length. Keeping your port widtih of 1.75
  • Who's Online   1 Member, 0 Anonymous, 1152 Guests (See full list)
