i just got an led light strip with 300 led. I hooked up about half of them today and they are running off my subwoofer terminals. When i went to bump them they started to smoke. I was wondering if anyone knew away where i can have them still go with the bass beats but not smoke when i turn it up all the way.
Thanks!
get resistors n get the beat box for em. its a little box that pushes power to the beat of the music.
Lucky Durango
Sony hu
4 croosfire 6.5mids
crossfire 600.1 mono amp
American bass 1280.4 mids and highs amp
aq hdc3 12
2.4 cube net box, tuned to 34 and 14.4 inches of port per cube
in all of my led d crap i use 410 ohm resistors. they work for all my 12volt needs.
Lucky Durango
Sony hu
4 croosfire 6.5mids
aq hdc3 12
1 to each strip only on the positive line
Lucky Durango
Sony hu
4 croosfire 6.5mids
aq hdc3 12
if your trying to get them to go to the beat, ad dont wanna go crazy with all the resistors, you could just wire it in to the Left or Right speakers on the headunit. my broth used to have lights behind his speaker grills in the door panels
doing as he stated can cause problems electrically. if you wanna go to the beat theres a special box to buy. and also its 1 resistor per set of leds if soldered to 1 strip.
Lucky Durango
Sony hu
4 croosfire 6.5mids
aq hdc3 12
Am i stupid or is hooking anything other than your subs to your amps speaker terminals going to change what ohm's the amp see's and thus possibly frying the amp? From what i gather you just need a module that has a microphone that tells the lights when to light up. Correct me if i am wrong.
