Nju Posted May 8, 2012 Report Posted May 8, 2012 Hi, i have been searching forever for an answer to this question and haven't found anything about it so here it goes. Im wondering in what order i should connect the cables, Im going to run 1 battery front and 1 in the trunk then to the amplifier. Starting off, removing negative cables from the batteries, Then should i connect the ground to the amplifier into the chassi FIRST ?, then rca,remote,speakerwire and last battery+ cable to the battery? And last of all the ground cables back to both batteries? Really appreciating an answer. thanks! //The noob
RandomHero Posted May 9, 2012 Report Posted May 9, 2012 First off, you can either run the both batterys together (+ and + - and -) or have the back battery (+ and + - to chassis) Number 2 seems to be the most popular method, althought number 1 works just as good (for dual battery's) Now you asked in what order you should connect the cables? Hook up + to + on batterys, keep the - disconected Choose a different grounding point in the trunk from the battery (if going with number 2 option) and ground the amp Hook up the RCA's, Then Speaker Wires, Then REM, then hook up the +. Now ground the front battery and then the rear. Dont forget to fuse your first battery AND your second one. Hope this helps 06 Corolla Ascent Kicker ZX300.1 Kicker Comp 12" Kicker KS600 x 4 Pioneer DEH7500 More to come - Firstly, need money. :\
Nju Posted May 9, 2012 Author Report Posted May 9, 2012 First off, you can either run the both batterys together (+ and + - and -) or have the back battery (+ and + - to chassis) Number 2 seems to be the most popular method, althought number 1 works just as good (for dual battery's) Now you asked in what order you should connect the cables? Hook up + to + on batterys, keep the - disconected Choose a different grounding point in the trunk from the battery (if going with number 2 option) and ground the amp Hook up the RCA's, Then Speaker Wires, Then REM, then hook up the +. Now ground the front battery and then the rear. Dont forget to fuse your first battery AND your second one. Hope this helps Thank you man! really helped alot. i just want to be 100% sure before i do something stupid with expensive stuff
