TheNewbie Posted May 12, 2012 Report Posted May 12, 2012 I was chattin with a guy that does electricity and he was saying I nees to wire each battery to the alt so I pull from then both rather than just the back. So that the front isn't being under or over charged.. Was I wrong to wire the front from alt to front batt then front batt to back back bat to amp? trying to explain to him it will pull from two but now I'm thinking perhaps I'm wrong. Check out my build log: http://www.stevemead...60#entry1958353 Different folks have different strokes.
gsr40freak Posted May 13, 2012 Report Posted May 13, 2012 Regardless if you do seperate runs or not... the alt postive is still touching the postive on the front battery. Its still one unit. The way you have it is fine and seperate runs arent needed. Alt positive ---> Front Batt ---> Back Batt is fine.
TheNewbie Posted May 13, 2012 Author Report Posted May 13, 2012 Regardless if you do seperate runs or not... the alt postive is still touching the postive on the front battery. Its still one unit. The way you have it is fine and seperate runs arent needed. Alt positive ---> Front Batt ---> Back Batt is fine. alrighty thanks! Check out my build log: http://www.stevemead...60#entry1958353 Different folks have different strokes.
