Posted (edited)
Ok, running rough BEFORE or AFTER the plugs. Did you just stick them in without checking the gap?
And if it was AFTER the fact, what plugs did you use? I know some plugs in those motors don't play well.
Edited by Rebel4055
Rest In Peace mother.
January 22, 1955 - February 14, 2013
http://www.stevemeadedesigns.com/board/user/35351-megrch/
be4 and after and there gaped right
off hand i cant tell u what one i used but i have 2 videos of what it dose i will post them here in a bit
________________________________________________________________________
deepsilencer, on 22 Aug 2011 - 17:32, said:
splzx3, on 22 Aug 2011 - 17:27, said:
i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD
WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
Posted (edited)
by any chance did you clean the throttle body
Edited by bass_stalker
it not bad at idle it only when im driveing
Posted (edited)
http://youtu.be/KTBn9v51-I4
http://youtu.be/ERY6gHyrMmc
i know there not the best in the world
Edited by splzx3
the cyl misfire code is the one i dread the most because it can be caused by anything from intake seal , head gasket ,compression , injector , ignition , timing and probably a lot other things as well . i had a vehicle with a missfire and i started by checking the pcv , vacuum lines ,looking at wiring for anything obvious , switching wires from a known good cylinder , sprayed ether around the intake manifold seal while it was running to check the seal , finally a compression test revealed the cylinder with the misfire had low compression due to the head gasket leaking . if you plan to fix your own car the first thing you should get if you don't have it already is a repair manual and not chiltons ,get something better .
if you suspect the injector for that cyl you can see if you can trade it for another cyl
maybe i could go to your house and see for my self the problem.
Build Under Construction
Head Unit = Kenwood DDX514
Amps = Kicker 750.1, Going to install Sundown 1500D v3 and Sundown 125.4
Battery = XS D3400
Wires = Kicker RCA's, 0 Gauge street wire and Stinger
Mids and Highs = Stock
Sub= Kicker L7 12"
Alternator = 220 Mechman
Sound Deadner= Fatmat and Stinger Road Kill
  • Who's Online   0 Members, 0 Anonymous, 739 Guests (See full list)
