Ok, running rough BEFORE or AFTER the plugs. Did you just stick them in without checking the gap?
And if it was AFTER the fact, what plugs did you use? I know some plugs in those motors don't play well.
Edited by Rebel4055
Rest In Peace mother.
January 22, 1955 - February 14, 2013
http://www.stevemeadedesigns.com/board/user/35351-megrch/
be4 and after and there gaped right
off hand i cant tell u what one i used but i have 2 videos of what it dose i will post them here in a bit
________________________________________________________________________
deepsilencer, on 22 Aug 2011 - 17:32, said:
splzx3, on 22 Aug 2011 - 17:27, said:
i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD
WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
by any chance did you clean the throttle body
Edited by bass_stalker
it not bad at idle it only when im driveing
http://youtu.be/KTBn9v51-I4
http://youtu.be/ERY6gHyrMmc
i know there not the best in the world
Edited by splzx3
the cyl misfire code is the one i dread the most because it can be caused by anything from intake seal , head gasket ,compression , injector , ignition , timing and probably a lot other things as well . i had a vehicle with a missfire and i started by checking the pcv , vacuum lines ,looking at wiring for anything obvious , switching wires from a known good cylinder , sprayed ether around the intake manifold seal while it was running to check the seal , finally a compression test revealed the cylinder with the misfire had low compression due to the head gasket leaking . if you plan to fix your own car the first thing you should get if you don't have it already is a repair manual and not chiltons ,get something better .
if you suspect the injector for that cyl you can see if you can trade it for another cyl
maybe i could go to your house and see for my self the problem.
Build Under Construction
Head Unit = Kenwood DDX514
Amps = Kicker 750.1, Going to install Sundown 1500D v3 and Sundown 125.4
Battery = XS D3400
Wires = Kicker RCA's, 0 Gauge street wire and Stinger
Mids and Highs = Stock
Sub= Kicker L7 12"
Alternator = 220 Mechman
Sound Deadner= Fatmat and Stinger Road Kill
  • Who's Online   1 Member, 0 Anonymous, 1650 Guests (See full list)
