Ok I have 2 RE Audio mx 15 d2 in a box that is 3.5 cubic feet after displacement and tuned to 34 hertz I am running a hifonics colosus amplifier @ 1 ohm is 1600x2 watts rms. The subs are rated at 1500 rms each. At the last two shows I have only hit a 141.9 and I am thinking I may need a different box. looking for box sizes and tunning advise.
amp specs
http://www.sonicelec...s-Colossus.html
sub specs
Features:
  • 15" Competition subwoofer
  • Dual 2 ohm voice coils (This gives you the best wiring options!!)
  • (This is also available in dual 1 ohm voice coils in our store)
  • 3000 watts peak
  • 1,500 watts RMS rated
  • Tested and legitimate real world RMS power ratings
  • One-Way, Linear Excursion -Xmax: 22 mm (this is one of the highest excursion subs in our store)
  • Dual Composite 2-piece Cone
  • Rubber Surround
  • Integrated Gasket
  • Cast Aluminum Basket
  • Tork-Tite Terminal
  • 4” 4-layer Aluminum Voice Coil
  • FEA Optimized Motor Structure
  • Powerful Neo Magnet
  • Dual Progressive Spiders
  • Integrated Tinsel Lead
  • Mounting Depth - 11”
  • Mounting Hole Diameter - 14.5”
  • Overall Diameter - 16”
  • Bolt Hole Circle - 15.25”
  • Motor Width - 8.5”
  • Motor Depth - 2.5”
  • Basket Depth - 8.5”
  • Displacement - 0.22 cu. ft.
  • Electrical Q Value -Qes: 0.561
  • Mechanical Q Value -Qms: 3.098
  • Total Speaker Q Value -Qts: 0.475
  • Free Air Resonance -Fs: 20.775 Hz
  • Equivalent Compliance -Vas: 166.25 liters
  • Efficiency -SPL 1W/1m: 86.113 dB SPL
  • Effective Piston Area -Sd: 810 cm^2
  • Sealed Compact: 1.5 cubic feet
  • Sealed Optimal: 2.0cf
  • Ported Compact: 3.0 cubic feet tuned @ 35Hz
  • Ported Optimal: 4.0 cubic feet tuned @ 33Hz
02 Trailblazer
Soundstram vir 500 Head Unit
Audiopipe line driver
Hifonics Collossus (1600 X 2 @ 1 ohm rms)
2 15 RE MX custom box 3.5 net cuft per side tuned @
MTX TE404 highs amp
MTX 6.1 compnents in front doors
Focal 6.5 in rear doors
Kenetik 2000 watt battery in rear
Python alarm system
  • Who's Online   0 Members, 0 Anonymous, 1125 Guests (See full list)
