Scanyland Posted May 31, 2012 Report Share Posted May 31, 2012 Haven't really posted here before but I am not new to the whole car audio thing. I have come across a problem I need some help with. I started about a month when I moved my system to a different car I blew my inline 80A fuse. I started by checking and redoing my ground and then installed another 80A fuse and that blew about a day later. I then realized I didn't upgrade my fuse when I got a more powerful amp (the old amp was around 400 watts rms and the new one is 1200 watts rms. So I went and installed a 200A fuse and when I hooked everything back up I got smoke from one of my two subs. Isn't a huge bummer since I wanted to get new ones any way. I pulled the bad sub out and then tested the one good sub and that worked just fine. I only tested for about 30 seconds. Now I wanted to know if it is possible for a bad sub to draw too much current and in turn cause the inline fuse to blow or is the amp to blame. I want to make sure before I get two new subs and have them go bad because of a bad amp. The equipment I was running was 2 Alpine Type R's (SWR-1224D) and a MTX JH2400 amp. Link to comment Share on other sites More sharing options...
Rebel4055 Posted May 31, 2012 Report Share Posted May 31, 2012 User error. Gains are probably set improperly or crappy ground. And you fuse to the wires limits. The fuse is to protect the wire. Rest In Peace mother. January 22, 1955 - February 14, 2013 http://www.stevemeadedesigns.com/board/user/35351-megrch/ Link to comment Share on other sites More sharing options...
