Gain matching+filter setting
armykyle1
So on this next run I plan on running my amps not strapped.
I know how to gain set with a DMM. Xovers I typically do by ear.
My plan of attack is to DD-1 both amps, check output voltage of both amps and match to the one with less output.
Now I'm not worried about setting the LPF on the amps since I can do that via the HU. My only area of concern is the SSF. I'm a little fuzzy on gain matching with the SSF.
Do you play your selected tone of choice (lets use 30hz in this example) continue to turn the filter up until you see a dip in output voltage? Then repeat on the second amp.
I'll most likely use Y-splitters for the RCAs to ensure proper distribution of pre out voltage instead of the output on the amps. Eventually I'll use some sort of Bass eq to bring the voltage back up.
  • Who's Online   0 Members, 0 Anonymous, 1041 Guests (See full list)
