hey guys i need help? i already have 16 awg speaker wire hooked up from sub to amp and was wondering if i should switch it out for 14 awg speaker wire? will it make any difference in sound or performance if i do switch? also, i am currently running 8 awg power wire from amp to battery. i am using a rockford fosgate R500-1 amp and didnt know if i should switch to a 4 awg wire? would it make a difference in sound or performance if i do?
thanks,
RF_kid
my preference is to use the best wire i can afford , of course bigger wire is better , and ofc copper is superior to many other wires as well . one thing that doesn't cost is keeping your runs as short as possible .
http://www.knukonceptz.com/productDetail.cfm?prodID=KRD10BL
i bought some of this a while back and have been using this for wire subs until you get into big big power 10 gauge is probably plenty good , to answer your question though , i don't you would see a noticeable difference going from 16 - 14 gauge wire unless the wire you currently have is super shitty .
8 gauge copper should be good enough for that amp , personally i wouldn't run anything smaller than 4 gauge period . i would plan on bigger wire if you want to add any more amps or go to a bigger amp for subs .
if you ever feel your power cable getting hot you should think about going with a bigger cable
  • Who's Online   0 Members, 0 Anonymous, 627 Guests (See full list)
