andrew018018 Posted June 30, 2012 Report Posted June 30, 2012 Well i sold my old amp about a week ago to a friend and he's already blown it, i'm not exactly sure what he did but it's shorted out. Basically when you put a multimeter on the positive and negative terminals it reads 0 ohms, i tested all the mosfets and they seem fine, but when i came to test the transformer i run into a problem because the power supply is shorted i cant read the resistance across it since it reads 0 ohm everywhere... unless i pull it off the board i dont know what to do Anyway, what are the main causes of a shorted amp and what testing methods can i use thank you My System (in VW golf/Rabbit mk2) (1) Hifonics Brutus 2010D @ 1ohm (1) Hifonics Zeus 440 Mids'nhighs (3) JBL W10Gti subs (2) JBL GTO838 (2) JBL GTO936 (1) run of 3/0 Gauge ofc (1) Ac Delco120ah 850cca battery (front) (1) Ac Delco 45ah 330cca battery (rear) (1)Sony Gt630ui hu 34hz tuning
andrew018018 Posted July 2, 2012 Author Report Posted July 2, 2012 I pulled off all the mosfets from the power supply, just to make sure that they weren't shorting the amp out, but as I concluded before the mosfets are fine and the amp is still shorting out... So does this mean the amp has a blown transformer? or could it be something else? My System (in VW golf/Rabbit mk2) (1) Hifonics Brutus 2010D @ 1ohm (1) Hifonics Zeus 440 Mids'nhighs (3) JBL W10Gti subs (2) JBL GTO838 (2) JBL GTO936 (1) run of 3/0 Gauge ofc (1) Ac Delco120ah 850cca battery (front) (1) Ac Delco 45ah 330cca battery (rear) (1)Sony Gt630ui hu 34hz tuning
andrew018018 Posted July 2, 2012 Author Report Posted July 2, 2012 Uploaded with ImageShack.us here is a photo, it a kenwood 8104D My System (in VW golf/Rabbit mk2) (1) Hifonics Brutus 2010D @ 1ohm (1) Hifonics Zeus 440 Mids'nhighs (3) JBL W10Gti subs (2) JBL GTO838 (2) JBL GTO936 (1) run of 3/0 Gauge ofc (1) Ac Delco120ah 850cca battery (front) (1) Ac Delco 45ah 330cca battery (rear) (1)Sony Gt630ui hu 34hz tuning
