This is a few speaker boxes that I've built, they are quite easy to make, You just need to do the math for enclosure size, before choosing your sub or subs. I know that they are not as nice looking as what I've seen here so far but it gives you an Idea of what you can do.
I used 1/2" felt under the carpets and under that I used a product that I bought at Home depot called "Quick Roof" directly on the floors of this car as a sound deadener. Quick roof is just like Dynamat extreme ( asphalt based, heavy foil lined, peel and stick ) but only at a fraction of the cost. A 6" x 25' roll is $17.00 and Dynamat last time I checked was $10.00 per square ft.
also used fiberglass insulation stapled to the inside of the enclosure.
This first one was made with t-shirt material
when you build your box, you need to leave the bottom out of it until the last step. this sub box in the middle was a 1.25 cu.ft. and ported
Prop rings up with dowels, either glue them or screw them down
staple t-shirt material tightly over speaker rings
fiberglass resin brushed on top of T-shirt material
apply 4-5 layers of fiberglass to the underside of the material and wood only, nothing goes on top except bondo later on
steps
done
pod after paint
pod finished
10" dvc Quantum audio subwoofer, Sony 5.25" and 6.5" coaxials, Sony 780watt 2 channel amp, clarion 200watt 4 channel amp, 2 farad boss capacitor, clarion head unit, clarion 7 band equalizer w/ separate subwoofer gain controls and a high amp alternator.
This next one was done with fleece material, it is thicker so it held more resin plus less bondo had to be used for imperfections at the end.
This is what I'm running in mine there is a box underneath the shelf that you see here. I originally had it in my '67 bug some 15 years ago.I had crossfire subwoofers in it back then.
I'm going to build yet another fiberglass box instead of this one, pretty soon so I'm looking around for more fiberglass ideas
2 JL audio 10" 8ohm connected in parallel.
planet audio head unit, a boss eq with sub output not seen here because it is under cup holder
Crunch audio amplifiers a 4 channel 600w, a 500w for the subs and a 5 farad cap
Edited by the moose
1974 VW Beetle
2- JL Audio 10w08 subs in ported fiberglass enclosure
Hifonics ZRXLP 6.5C (fronts)
Hifonics HRC 5.2C (rears)
500w Crunch powerzone amp (subs)
600w Crunch powerone amp (components)
3 farad power acoustics cap.
head unit- Planet Audio P385UA
Boss eq 1208
I'm just looking around for new ideas for my next one. I was planning on using one 12" sub, with either two 6x9's or two mid bass 5.25's I also have two aluminum horn tweeters that are just kicking around here, I might incorporate them with the mid bass drivers. I still haven't decided which way to go?
Edited by the moose
1974 VW Beetle
Boss eq 1208
  • Who's Online   0 Members, 0 Anonymous, 1196 Guests (See full list)
