Voltage drops to only 13.8.... Should be way more
i did, resistance at coils is 2.7, then each is 5.4-5.6 after series, normal
each sub is wired in series, then in parallel at the amp,
the final load is 2 ohms, 100% sure.
i assume the subs just arent getting enough power.
this thing isnt even doing a 140 according to my ear-o-meter. maybe a 135
bad bad bad
OK now that im thinking about it, i figured out your problem,
your giving each sub 750w RMS, I bet if you just hook up one of those wired at the 2 ohms and give it the full 1500 it will be louder than the both of them,
the 9512 wont move off of 750, well it will, but now how you want it to.
When I graphed out the 9500 12 there were drastic performance differences after passing 1000 watts on the driver.
So, that beeing said, you are in bad need of
  • Who's Online   0 Members, 0 Anonymous, 1491 Guests (See full list)
