Saltine Posted July 6, 2012 Report Posted July 6, 2012 going a different route b/c i want to go louder. 2 Fi audio 18" loaded BL's 2008 model heres the sub specs DUAL 1 Fs: 33.2 Hz Re: 0.7 Ohms/coil Qms: 5.82 Qes: .32 Qts: .30 Mms: 302g Cms: 0.88mm/N Sd: 1210cm^2 Vas: 181.0 l Spl: 94.1dB 1W/1m Bl: 16.6 N/A Xmax: 18mm Rms: 1500W * Sealed box: N/A cuft Ported box: 5-8cuft Sub OD: 18.500” Cut ID: 16.750” Mounting depth: 9.750” * Displacement: 0.26cuft * would like to be tuned around 32-33hz for maximum thump, think Fi recommends 33hz maximum space to play with, all outter measurements given height 23" width 56" depth 26" gives around 16cuft at those measurments going behind my seats of my fleetwood where the backseat usually is. witht he exception of height the width and depth can be reduced if need be. I dont need a virtual box picture just what size would you build it and port width length and depth to get that 33hz range for maximum thump
