RodneyHawkins Posted July 11, 2012 Report Posted July 11, 2012 I have had my system for 2 monthes, the amp kit i got sucked and had non of the ring terminials and i also have a side post battery... It was not "properly" set up and now i am looking to fix it.. I have to side post battery adapter and the ring terminials now,, I have been looking and what is the best was and how to connect the ring terminals to battery terminal
Guest Posted July 11, 2012 Report Posted July 11, 2012 Get rid of the ring terms if your going to run post and run something like this, http://www.tsunamion....com/BT703.html
Reg_Cab_Slammer Posted July 11, 2012 Report Posted July 11, 2012 I think he just got the bolts for a side post battery. But the bolts have a special part for the ring terminals right? Of thts the case just solder ur wire in and heat shrink over. Then put ur wire terminal on you battery post bolts 2001 Dodge Ram Kenwood Deck Pioneer speakers
andale927 Posted July 12, 2012 Report Posted July 12, 2012 I have had my system for 2 monthes, the amp kit i got sucked and had non of the ring terminials and i also have a side post battery... It was not "properly" set up and now i am looking to fix it.. I have to side post battery adapter and the ring terminials now,, I have been looking and what is the best was and how to connect the ring terminals to battery terminal Please post a picture, no one will be able to help you properly without one. Upload to photobucket.com and then use the img code to put it in your post.
