How would I go about "dynamatting" my trunk? And I know this stuff is not the best, but that's what I can afford right now. Eventually I'm going to get some Damplifer Pro.
And I know this isn't dynamat, I just used that saying.
Edited by Avery Howell
2012 Jeep Wrangler 3.6 W/ 6 Speed
Build Log
2011 Ford F-150 SVT Raptor 6.2
Build Log
YouTube
its called sound dampening/deadening, not dynamatting. just letting you know.
what do you mean how do you go about it? just take the carpet off, if there is, and use a small roller that usually comes with packs of deadener, to press it onto the metal.
you should clean the metal beforehand also before applying the deadner.
I posted a pic and thanks idk why I used dynamatting. Any way There's a bunch of big holes in the trunk panel basically. You really have to look at the pic to see what I'm talking about.
Build Log
Build Log
YouTube
what about them?
what about them?
Do I just out the dampener over the holes? They're pretty big but I can do it. Then there's metal behind the holes too.
Build Log
Build Log
YouTube
what about them?
oh you mean those giant gaps between the inner metal and the outer metal? no dont bother covering those. its just a waste of deadener.
what about them?
Do I cover the inside metal?
Build Log
Build Log
YouTube
yes. i already see you have a couple spots done on the inside part. just finish that up and you should be good. im no genius at deadening though
you can always fill the holes with foam... and then cover the foam in deadening..
thats a tad overkill
That won't deaden the other metal tho bro
Build Log
Build Log
YouTube
  • Who's Online   0 Members, 0 Anonymous, 771 Guests (See full list)
