I think sundown says 3-4 each. so after port displacement u want to be between 6-8 cubes. id say 21hx34wx24d. port would be 20.5x5 use 3 common walls and make it 24 long. That will give u 6.4 cubes tuned to 35ish hertz. also id put the subs up and port back
Posted (edited)
threw something up really quick. you could probably not use the extra baffle, but i just put it in there
Edited by Kranny
Posted (edited)
saw that you had a blazer/jimmy. do sub up port back. port in the center. you're not gonna bend the port in this design, so it'll be easier to build.
Edited by Kranny
Kranny that might choke the port off if he gave u dimensions right up to the back of the vechile
this is true. OP needs to clarify
