budah93 Posted July 21, 2012 Author Report Share Posted July 21, 2012 so should i go closer to 8 cubes with similar port area? Quote Link to comment Share on other sites More sharing options...
Ddub847 Posted July 21, 2012 Report Share Posted July 21, 2012 I think sundown says 3-4 each. so after port displacement u want to be between 6-8 cubes. id say 21hx34wx24d. port would be 20.5x5 use 3 common walls and make it 24 long. That will give u 6.4 cubes tuned to 35ish hertz. also id put the subs up and port back Quote Link to comment Share on other sites More sharing options...
Guest Posted July 21, 2012 Report Share Posted July 21, 2012 (edited) threw something up really quick. you could probably not use the extra baffle, but i just put it in there Edited July 21, 2012 by Kranny Quote Link to comment Share on other sites More sharing options...
Guest Posted July 21, 2012 Report Share Posted July 21, 2012 (edited) saw that you had a blazer/jimmy. do sub up port back. port in the center. you're not gonna bend the port in this design, so it'll be easier to build. Edited July 21, 2012 by Kranny Quote Link to comment Share on other sites More sharing options...
Ddub847 Posted July 21, 2012 Report Share Posted July 21, 2012 Kranny that might choke the port off if he gave u dimensions right up to the back of the vechile Quote Link to comment Share on other sites More sharing options...
Guest Posted July 21, 2012 Report Share Posted July 21, 2012 Kranny that might choke the port off if he gave u dimensions right up to the back of the vechile this is true. OP needs to clarify Quote Link to comment Share on other sites More sharing options...
Ddub847 Posted July 21, 2012 Report Share Posted July 21, 2012 OP can we get clarifaction Quote Link to comment Share on other sites More sharing options...
budah93 Posted July 21, 2012 Author Report Share Posted July 21, 2012 i really don't wanna go much deeper than 24 or 25" i posted my max dimensions in my original post Quote Link to comment Share on other sites More sharing options...
Ddub847 Posted July 21, 2012 Report Share Posted July 21, 2012 use the box specs i posted Quote Link to comment Share on other sites More sharing options...
budah93 Posted July 21, 2012 Author Report Share Posted July 21, 2012 alright and by subs up port back you mean subs facing the roof and port facing the back hatch correct? Quote Link to comment Share on other sites More sharing options...
