b-dubs89 Posted July 30, 2012 Report Posted July 30, 2012 i have an oscope for the purpose of setting amp gains and checking preamp signals , my question this : say i have an am p that is rated 400 watt @ 4ohm 700 watt @ 2ohm 1000watt@ 1 ohm so if i connect the oscope to the speaker output an set everything to get an unclipped signal and from there i connect a sub set up that yeilds 1.33 ohm load am i still good ? or is there more to the picture still ? thank you in advance for any helpful info on getting going with the in and outs of oscopes and car audio .
Guest Posted July 30, 2012 Report Posted July 30, 2012 gains dont change if you wire 4 ohm, 2 ohm, 1 ohm, or anything inbetween. once you set it with the scope, you're fine
