I have a Audio Control EQS that has a built in line driver and have used the DD-1 to find the distortion limit on the head unit. After that do i keep the head unit volume just under the limit i found and go to the line driver adjustment on the EQS and measure the out put on the DD-1?
What is the step by step procedure for the equipment i have.
Headunit -> Audio Control EQS -> 1-4channel amp for the doors -> 2- mono amps for the 2-subs (1 amp powers each sub) and using the DD-1 and the CC-1.
Thanks in advance
