help for choseing extra batteries
so i already have 1 xs d1400 under the hood and want to put either 2 d3100s or 3 d1400s in the rear but not sure if i could do it properly since one being a 14v battery and others 12v? but from what i see the d3100s are pretty beast
im running a dc 5.0k btw
thank you
98 Jeep Cherokee XJ 2 DOOR
1 18" T3 TSNS
DC 5.0K
Mechman 270 Unit
XS Power Flex 0 gauge
XS power D1400 under hood
3 Yellow tops in rear
1990 BMW e30 325i (drift car)
system to come
only way to "safely" do it...(what the company recommends) is to charge no higher than 14.8-14.9 for the D3100's sake and use an external charger for the 1400 to top it off regularly since 14.8-14.9 wont top that 1400 under the hood off.. now thats just staying under manufacture specs but many people run their charge at mid to high 15's on the xs power 12v batts with no problem its just not recommended from the manufacture. cause i think 16.4v is recommended for charging the 1400's?
1 Fi Sp4 18
Crescendo 2k
selenium mids
audioque supertweets
Hifonics for mids and and highs
1/0 power and grounds
---> on the way singer alt and possibly another
2k depending how sub likes 1 2k
thank you
and if your running just one 5k and have a mechman 270 with big three done and multiple runs of zero to the back(2+ and 2-) one may two more 1400's in the rear should be plenty assuming your not running it below 1ohm... a buddy of mine runs is set up at 15.1v with a 250 dc power alt kinetic 2000 under the hood and 1 xs d3100 in the rear with two runs and of zero to the back and and get barely any drop running his 5k at full tilt (drop to 14.8 at the lowest)
1 Fi Sp4 18
Crescendo 2k
selenium mids
  • Who's Online   0 Members, 0 Anonymous, 1209 Guests (See full list)
