BigPimpin91 Posted January 12, 2008 Report Share Posted January 12, 2008 I'm a little bit confused as to what it means. I'll explain what I think it means and correct me as need be. OK you have two of the same brand and rating amplifiers. My AudioPipe 1500 for EX. You wire your subs at 2 ohm's. You then split those wires to both of the amp's output's observing proper polarity. Thus, the amp's read 1 ohm each and I now have 3000w R.M.S. You have the Settings adjusted on the first amp and have an RCA jumper from the Master amp to the Slave amp's Bridged Input so nothing is out of phase etc. Is that the correct definition? Thanks. Quote BigPimpin91's Banging Music Link to comment Share on other sites More sharing options...
01xtreme Posted January 12, 2008 Report Share Posted January 12, 2008 (edited) When strapping an amp you are essentially bypassing all the equalization and controls of the "slave" unit and controlling both amps through the "master" amp. In most cases I have seen the master amp's positive outputs act as the positive ouputs for both amps, and the positive outputs of the slave amp is used as the negative output for both amps. the negative terminals of both amps are linked, and the amps are strapped through either a phone type cable, or an RCA cable. Hopefully this isn't too confusing of an explanation. you have the ohm levels right, each amp is seeing half the ohm load shown to the strapped pair. essentially it is like bridging a 4, or 2 channel amp, but you are using 2 separate amps. Edited January 12, 2008 by 01xtreme Quote My System: Pioneer AVH-P3200BT 4-Dayton 7 inch reference series (front doors) 8-Onkyo 3/4 inch tweeters (dash) 1-Sundown Audio 100.4D (mids/highs) 2-18" BTL's (for now) Crescendo 3kwp (for sale) Complete rebuild coming soon... Link to comment Share on other sites More sharing options...
BigPimpin91 Posted January 12, 2008 Author Report Share Posted January 12, 2008 So it is exactly like the Audiopipe website says. My amps are strapable. But in a weird way. I will try to post a picture of the manual in a minute. Quote BigPimpin91's Banging Music Link to comment Share on other sites More sharing options...
01xtreme Posted January 12, 2008 Report Share Posted January 12, 2008 So it is exactly like the Audiopipe website says.My amps are strapable. But in a weird way. I will try to post a picture of the manual in a minute. ok. it will probably help make more sense with the manual. Quote My System: Pioneer AVH-P3200BT 4-Dayton 7 inch reference series (front doors) 8-Onkyo 3/4 inch tweeters (dash) 1-Sundown Audio 100.4D (mids/highs) 2-18" BTL's (for now) Crescendo 3kwp (for sale) Complete rebuild coming soon... Link to comment Share on other sites More sharing options...
BigPimpin91 Posted January 12, 2008 Author Report Share Posted January 12, 2008 (edited) What's funny is that they use The two positives for output's. You would think that the positive of one amp would go to negative of the other and you would have one positive and one negative output. P.S. Sorry about the head tilting. Edited January 12, 2008 by Bigpimpin91 Quote BigPimpin91's Banging Music Link to comment Share on other sites More sharing options...
