How do i fit all of that in there!?
put one wire threw the front and the other threw the back :D
I felt dumb founded when I read this it makes so much seance it's not even funny we all try to shove both in one side
my wire is too big for that
twist them tight and angle the first one down then slide the second one above it i used 10 on my old sub its was a very tight fit
I think i am going to stick to bolts but thank you very much for the input.
no prob :D
10g? really? looks more like 8g..anyways, you should be able to squeeze two minutely trimmed 10g into a terminal. I did what you're doing with 8g. Yeah took hours to finish. Use the lineman pliers like he posted above, that will compress the wires to a very efficient small diameter and you should be able to get them in. If you're running a lot of power/low Fs/etc, then try to stay away from banana plugs and such, as they have a tendancy to get loose and create heat and start melting plastics around them, and also heat up the amp from resistance issues, not to mention possibly shorting out the terminals. I gave up on BJ's after too many times of cumming out lol.
OT, holy fucking Interests...lol
POTATO!
  • Who's Online   1 Member, 0 Anonymous, 1640 Guests (See full list)
