Joshex's 93 Civic RETIRED! Last page read for details.
Just picked up an AQ1200d for $150 today from Integra_boomer. I can post some pics up some time, but I'm going to manhattan this weekend.
95 Acura Integra - 5-speed
Pioneer FH-X700BT
(2) Rockford Fosgate 12" P3
AQ1200d
Rockford Fosgate P1652-S 6.5" components
Rockford Fosgate P1572 5x7"
Rockford Fosgate R400.4
95 Integra Build Here
93 EJ2 Build Here
So, I nominated myself for SOTM! I believe my build is 95% done with my audio at this point, like I said before, all that is left is my electrical. The only reason I haven't upgraded fully yet is money.
Pioneer FH-X700BT
AQ1200d
93 EJ2 Build Here
sweet car, love to see people completely redo something and make it look 100x better.
I love doing it too, wish I didn't have school and had a job and my builds would be so much better!
Pioneer FH-X700BT
AQ1200d
93 EJ2 Build Here
just wanted to know if you built that sub enclosure yet? There are a couple flaws in your Torres Calculator mock up....first off you don't have any number of port walls listed, from your sketch it looks like you need 1 common wall in that spot, also it shows you only had around 8inches of port per foot and that is not good, you should be at least running 12inches of port per foot but more would be better like around 15-16inches of port per foot...so I would suggest recalculating your enclosure...
btw, you took that interior from a train wreck to stunning....keep up that kind of work!
Alright I've had some questions about the box, I know the mock up was a bit messed up, but I've fixed a few things and have looked into the porting and was wanting to know some opinions. I would like to get some help on porting this bitch to move a little more air then my prefabbed box. I would like to be tuned around 28-32hz. I would like a port without a bend, but I have tried and I keep failing. The problem I was having was having the port per foot above 12 inches, can I get some help here?
Torres:
Drawn design:
90231477-47b1-4f95-87a6-8e210313eacf_zps
b6dabf8a-a41c-4df1-996b-18929fa4a540_zps
Pioneer FH-X700BT
AQ1200d
93 EJ2 Build Here
I thought subs up in a trunk was a bad idea cause it rattled like crazy?
1999 Honda Civic- RIP
2003 Acura RSX Type-S
Well, I have it sealed and I'm going to do more to it.
But I would like to here more opinions on this as well.
Pioneer FH-X700BT
AQ1200d
93 EJ2 Build Here
Got the design finished, might do it over my spring break.
Pioneer FH-X700BT
AQ1200d
93 EJ2 Build Here
A wild package appears!
68B14D15-79E8-4B49-837D-2D6371DFC416-208
F0DCF03D-7B23-4A81-B931-D7F94E77E177-208
Pioneer FH-X700BT
AQ1200d
93 EJ2 Build Here
Spring break I have decided I'm going to clean my system up and make it pretty. I have been very busy with everything lately and have been a bit lazy. But I'm going to have a lot to do and hopefully I will finish by the end of my spring break.
Pioneer FH-X700BT
AQ1200d
93 EJ2 Build Here
