Truconcept Posted October 29, 2012 Report Posted October 29, 2012 should i ground the negative on the battery in the trunk to the same ground the amps are on? i dont know much about looping grounds im not going to run a negative from the battery under the hood to it unless i have to **actin bad like a kid at six flags**
Blackedout Posted October 29, 2012 Report Posted October 29, 2012 The best ground is a ground from the front battery to the back battery. Ground amps off back battery. In your situation a good ground off the battery and grounding the amps on the battery post is normally the way I go about it without an isolated ground. Trunk Build Log
