Mechman 270a Alt w/ AVBM
1. Product:
Mechman 270a HO Alt with adjustable voltage boost module (AVBM)
Comes with AVBM setting instructions and installation instructions.
For 4.0L Jeep
Im going to call Mechman on Monday and try to get a full listing of applications.
Fits 93-98 Grand Cherokee 4.0L (I had it on my 98)
Fits 91-98 Cherokee 4.0L w/ slight factory alt bracket grinding (pic and link below)
Fits 93-98 Grand Cherokee 5.2/5.9L (needs 7 rib pulley $30)
Fits Dodge 5.2/5.9L (needs 7 rib pulley $30)
Fits SRT4 Neon (needs 4 rib pulley $30)
Should fit more vehicles listed below.
2. Specs:
Tested at 14.1v produced 141a low speed output, 273a high speed output. Tested on 10-14-11 was installed/used for less than 1 full year.
3. Description/Condition:
Used/installed for a little under 1 year.
Was still working great when I took it out. No bearing or shaft play.
4. Price: :
$285 shipped CONUS only
No Trades. Unless you have a brand new Detroit Truetrac for a dana 35 axle or a complete Ford 8.8 axle assembly and I will add cash. :P
5. Pictures:
Just got off of the phone. Wasnt a whole lot of help since he was just going off the top of his head. lol
I think it could possibly fit more apps than this but its all he mentioned on the phone.
SRT4 Neon (needs a $30 4 groove pulley)
5.2L & 5.9L Dodge (Durango, Ram, etc.) (needs a $30 7 groove pulley)
According to some research online it should also fit:
93-98 Grand Cherokee 5.2L & 5.9L (would also need the $30 7 groove pulley)
91-98 Cherokee 4.0L
91-98 Cherokee 2.5L
91-98 Wrangler 4.0L
91-98 Wrangler 2.5L
91-92 Comanche 2.5L
91-92 Comanche 4.0L
97-98 Dakota 2.5L
Does this fir the 01 4.0 cherokee? I got someone real interested
As long as the mounting tabs look the same and it uses field terminals on the stock alt setup. It will work with the AVBM.
edit: Just looked online and it looks like it would bolt in place but would need a different AVBM since the 01 alts dont use the same style field terminals on the factory harness.
Heres a pic of how the AVBM hooks up to the field terminals on the factory harness. You would need this setup for it to work properly.
