scooter99 Posted November 10, 2013 Author Report Share Posted November 10, 2013 Made my first cut and it was a success. Acutally cuts it like butter. I'll go ahead and change the blade when I'm done with this before I try to cut any wood LOL! First piece of many! Pretty good cuts. Damn near perfect These are the front and back bottom pieces. Box bottom put together, nothing attached yet. Taking a look at it, I don't like how it's got that much space. So I decided to change it up a little. Got it all tightened up, and sitting flush with the bottom. Got the 4 corners cut Again, all damn near perfect cuts Mocked up. I dropped the top down below the spot where it widens out. This will give me a nice tight box. To hold them in, I'll be adding in a couple of wings, when the 3 boxes are all put together, and make some mounts for tie downs. That's later though. Taped them so that I could get accurate measurements for the top cross pieces. See the side on here. Facebook Page: S99Creations 2006 F250 Lariat Build Link to comment Share on other sites More sharing options...
scooter99 Posted November 10, 2013 Author Report Share Posted November 10, 2013 Front top piece. This one is a little small, but I'll make the adjustment for the rest of them. All of these joints are going to be widened about 1/16" each, so this will widen out a touch. I'm thinking about putting in some deadener too. But we'll see how much room I have when it's done. Here are some of the things I picked up from Depot yesterday for this. A piece of steel to do the brazing on, a square, an extension hose for the gas, and some brazing rods. I actually picked up the brown one a while back but found out that the aluminum brazing is mainly used with the blue ones. Not sure if the brown package is usable or not. I'll give it a try. All the pieces ready to be sanded a bit and then be put together and brazed. Marked the fence on my chop saw so that I could do one box before I cut 5 more boxes worth. That way if the first box isn't going to work or isn't strong enough, I don't waste time and money by cutting all these other pieces. Next step is to clean off this bench, from the truck project. After that I'll get some durrock down on the bench and put the steel plate to it. Hopefully with the durrock on the bench, I can prevent too much heat getting to it and not cause a fire. Just in case I'll have a fire extinguisher handy. After that, I can get the first box done up. So that's it for tonight. Tomorrow I'll get some more done. Hopefully have a box put together to show you guys. Thanks for checking in! Facebook Page: S99Creations 2006 F250 Lariat Build Link to comment Share on other sites More sharing options...
scooter99 Posted November 11, 2013 Author Report Share Posted November 11, 2013 Ok let's get on with it. Pics and videos coming up! Going to get the pieces brushed up with the wire wheel on my bench grinder. And we have failure. Complete failure. I'm sure it's operator error, but I can't figure it out. I'm defeated officially with this one. I guess I'll have to go back to the drawing board. Facebook Page: S99Creations 2006 F250 Lariat Build Link to comment Share on other sites More sharing options...
scooter99 Posted November 11, 2013 Author Report Share Posted November 11, 2013 So here's a little video I shot explaining what the new design is. Pics after are described as well. At the bottom there, you may not be able to see it, but I had some L-brackets that held the floor up. Decided to use those to put a piece of wood on as a floor. This is the space that the batteries are supposed to fit in. Got a piece cut to put the batteries on for mock up. it's only 1/4" mdf, but it'll work for now. The floor base will be 1/2" birch. So it's not much thicker than this. Got the 3 batteries stacked. They're not in the cubby itself, but this is giving me an idea of height. There's some space above the batteries. This is good. Again, I only need about another 1/4". Measuring it, to the edge of that, I have about 5/8" - 3/4". So plenty to spare without any cutting. Looking at it, measuring behind the wall, I have about 1 1/2" to cut up if I need to. So here's the second battery moved back to the back of the fender. Gives me about 2 1/2" - 2 1/2" more depth. This is the deepest battery, the top one won't go back as far. SO I'm going to estimate about an 1 1/2" - 1 3/4" to play with for depth. Needed to remove that foam in there a bit, to get the second battery to slide over as far as I could get it. Facebook Page: S99Creations 2006 F250 Lariat Build Link to comment Share on other sites More sharing options...
scooter99 Posted November 11, 2013 Author Report Share Posted November 11, 2013 That's good. So you can see the, there's some trimming of the metal right there that needs to happen for the bottom battery to get in there. Wider view. Here it is all the way back. Also, it's probably going to have to go with the angle of the fender, and not squared up like the bottom one. Here you can see the top two angled and the bottom one is squared up. I'll have to see how it works when I get the box built. Here's another way I could go if I end up needing 8 total batteries. I love these little guys. Box building tomorrow. I think I'm definitely moving in the right direction now. Thanks for checking in. More tomorrow. Don't forget, if you have a comment or suggestion, head on over to my build log and make it there. If you want to get updates faster, then like and follow my facebook page. Both are linked in my signature below. Facebook Page: S99Creations 2006 F250 Lariat Build Link to comment Share on other sites More sharing options...
scooter99 Posted November 13, 2013 Author Report Share Posted November 13, 2013 Ok this is what i got done yesterday and tonight. Probably doesn't look like much, but last night was about a half hour to 45 minutes, and tonight was about an hours worth. LIttle bits at a time. Tomorrow night an hour or so more. This is my life! LOL But it's all I have to work with. If I can sustain it, then there should be pretty good progress every other day at least. We'll see. Ok on with the pics!! First up, last nights work. Driver side vent out, and pulling some deadener back. Passenger side vent out and pulling foam and deander. Cleaned up, line drawn, and ready to cut. Driver side cut. Wasn't as close to straight down as I wanted it to be. I just cant' go in any further or I'm cutting into the well and that wouldn't be good. So I'll have to figure out how to make this work. Passenger side cut. Pretty much the same thing on this side. I'll have to figure out how to make it work. I can still get another quarter inch out of this one if I need to. But only time will tell. Time to get down to business now. Now today's work. Got a couple of tools today for the curves and contours. These things are pretty cool. They just bend and are soft. These will help get close to the contours of the trunk. They're not actually meant for this. They're actually meant to like hold extension cords in a coil, or hold ropes, or whatever else. But because of their pliability I thought they'd be perfect for this. Kind of like this. Better view. Bend it until you get your shape. Takes some work. But you get the idea. Got the amp rack in for the first time since it was glassed! Remember that the back wall was terribly out of shape and not straight. Got that fixed! Grace in the back ground grazing on weeds! LOL Facebook Page: S99Creations 2006 F250 Lariat Build Link to comment Share on other sites More sharing options...
scooter99 Posted November 13, 2013 Author Report Share Posted November 13, 2013 Now it's time to get busy. Started with the cubbies because I knew those would be the toughest to do. Driver side. Bending it up until i think it's real close. This isn't going to be perfect, but it gets me close enough and after that some trimming and it'll be good. Take the stick and put it on some construction board Traced it with a sharpie A little love with the scissors and we have a template started. Not too bad. Did some trimming, a little too much on the left side there where you see the blue tape. The tape puts it back to where it needs to be. You can see how close it is here. I didn't have to trim that part. Oh yeah! Continuing on, I grabbed my other contour measuring tool and found this radius. See how this works? Now the driver side template is done. Made it so it goes right up to the amp rack, I'll probably rabbet out a bit of the base board, so it actually sits above the amp rack to keep it in place. I'm planning to add an inch all the way around the amp rack for overlay. Now time for the passenger side. Same thing, started with the stick in the cubby Moved around taping and cutting Then got the top part cut. Now it's all one piece. Just another view. Next up, I need to get it out of there, and get it cut into pieces of 1/4" MDF. From there, I'll transfer it to 3/4" Birch. Also need to get a rivnut kit so I can attach it to the trunk floor as well. Also got a couple things today. Only one can I show you though. The others are at work and I had left early so I'll have to get pics tomorrow. BUT IT WILL BE WELLLLLL WORTH THE WAIT I PROMISE!!! Got this from amazon today! Hmmmmm wonder what this could be for!! For those that already know, SHHHHHHHHHHHHHHHHHHHHH!!!! Not a huge deal but a pretty cool little additional project I think! So that's all for today. Tomorrow, I'll plan on getting the MDF pieces cut out with the Jig Saw, and ready for the birch and router. I know, an extra step, but I think it'll be ok. I have the MDF and I'm ok with that. I do have to figure out, if I want to go across the amp rack with the base board. It would go along the back wall, shown below, and come out about an inch. I'll decide that when I get started tomorrow. The purpose would be to link the two sides together, as well as, possibly to put led's under it. The other thing is I wish I could figure out where the enclosure was going. Then I could make the board 3 separate pieces. I'll see if I can't figure that out tomorrow too. Maybe I won't get all the way to cutting tomorrow. I might just have to wait and do some more measuring and marking. I'm just rambling. That's it tonight. Thanks for checking in! As always your comments and suggestions are welcome, just visit my build log linked in my signature below. Also like my facebook page, linked in my signature as well, for quicker up to date statuses and pictures. Still looking for that 100 likes so I can give some things away. Facebook Page: S99Creations 2006 F250 Lariat Build Link to comment Share on other sites More sharing options...
scooter99 Posted November 13, 2013 Author Report Share Posted November 13, 2013 So I've got a couple little updates. First one is this, the little secret project I was talking about before. Another piece to that. Then there's the big update. So I sold my XL 15's I got from Jon Rabe (Skyhighcaraudio in case you live under a rock), to Leo. I regretted it the day I packed them up and dropped them off. Leo probably doesn't regret getting them, but I can understand that. So ever since I said I was going to get another set of XL's. That would be the final goal. Well, some stars aligned, and Darion (Fosgatefeind) had a pair of perfect condition xl's up for sale. They happened to have the orange carbon fiber dust caps that I wanted to go with the theme of the install. Also has reinforced triple joints, extra spider, etc. Beef!! Well like I said the stars aligned and I was able to get them from him. They arrived yesterday, and I of course left work early to get my kids, and they came after that. So I just got to work a little while ago, and was worried all the way here about the condition of the boxes. I figured UPS drop kicked them off the truck or something like they normally do. Well let's take a look!!!! Direct lead And that ass Ohh MY OH MY THAT ASS!!!! Second one, just as beautiful as it's twin sister And the beautiful ass runs in the family! Yummy!!! So after picking these up, I think I'm gonna have to go with a triple baffle. These things are beefy. And the 12's basket on that XL motor makes them sooooo big!! I don't remember them looking so big on the 15's! Very excited to get these on my DMM and check em out and then get them in the car. Still a ways off from that, but I'll be counting days! WOOT!! Facebook Page: S99Creations 2006 F250 Lariat Build Link to comment Share on other sites More sharing options...
scooter99 Posted November 14, 2013 Author Report Share Posted November 14, 2013 Ok got a couple readings on the subs. All reading good at 2ohms. Coil 1 of 4 Coil 2 of 4 Coil 3 of 4 Coil 4 of 4 Facebook Page: S99Creations 2006 F250 Lariat Build Link to comment Share on other sites More sharing options...
scooter99 Posted November 15, 2013 Author Report Share Posted November 15, 2013 So as I said before I can only manage little bits at a time. Hour here, hour there, some more time invested on the weekends sometimes. So it's going to be slow, but it hopefully will be steady. I got another hour or so in tonight, and managed to get the floor template cut and ready. Let's take a look. Laid out some 1/4" MDF to get the template drawn out. That's 2 sheets there. It's only 2' x 4' per sheet. needed one more piece for the middle. Forgot about some trimming that needed to be done, you can see here. Black lines And here. Got it all laid out and in place tape to hold it in place while it's traced out. and got it drawn out. 3 pieces. In here I did not do a piece at the bottom because it's not going to go in in one piece because of how wide it is. Even if I cut it in the middle left to right, it'll still not fit. So I'll leave that out for now. Passenger side cut out Top middle cut out and then the driver side cut out and put it all together. Had some minor trimming to do, but it's in. Driver side Passenger side. Next up is getting this transferred onto 3/4" birch. I think before that happens, we'll have to figure out where the enclosure is going to come back to. So that's pretty much it for tonight. Like I said little bits at a time. Facebook Page: S99Creations 2006 F250 Lariat Build Link to comment Share on other sites More sharing options...
