speaker wire into rear doors (new question)
syclonewillie
I am working on a saturn ls2 sedan. I am putting rockford components in all the doors. I am running the crossovers in the trunk under the amps. I started running th wires around to the passenger side rear door. I found the rubber thing that goes into the door and there is a connector that fills the hole up right on the inside of the car. What is the best way to get the wires into the door? How have other people done it?
New question
I am running a pbr300x4 to rf t165-s in the front and t152-s in the rear. What size wire should i be running? I have 14/2 and 18/2 already but i can go get something else if need be.
You may be able to drill a hole in the plastic connector to run your wire through. Sometimes all of the pin holes in the connectors do not have wires in them you may also be able to run a wire thru one of them as well.
  • Who's Online   0 Members, 0 Anonymous, 1483 Guests (See full list)
