2003 Toyota 4Runner! alpine, kicker, and pioneer system build
each end soldered for that extra bit of contact.
New setup 8-9-13
headunit: kenwood excelon kdc x497
mids/highs: alpine type s 6.5 comps front/5.25 coax rear
substage: 2 PSI pf1 high performace upgraded 15's
mids/high amp: alpine mrx-f65
substage amp: DC audio 2k
optima (for the time) red top in back
skyhigh 0ga wires (minus sub amp, which is some borrowed 0ga, lol)
build log soon
inside the box, where the woofers will be wired in. sorry it is alittle blurry i forgot to focus
New setup 8-9-13
build log soon
outside, this is where the final load changes from 1 to 2ohm. woofers will be wired down to 1, and then connected at 2 and ran to the amp.
New setup 8-9-13
build log soon
New setup 8-9-13
build log soon
back plate put in. i shouldve put his before the wiring picture.
New setup 8-9-13
build log soon
i went ahead and put the last side on with brad nails
New setup 8-9-13
build log soon
failed to check to see if it was flush before i nailed it.. damn it! i got some liquid nails to fix it. the gorrila glue should help though
New setup 8-9-13
build log soon
liquid nailing the corners
New setup 8-9-13
build log soon
other side
New setup 8-9-13
build log soon
this is the gap from the previous picture. what gap now??
New setup 8-9-13
build log soon
