new box
vw passat
The first one is lacking port area per foot. the recommended Enclosure size for that sub is 4ft^3 net. If you can make the box bigger, try to get around 4ft^3 net, and shoot for around 62" of port area.
2 HDC3 18's
AQ2200D
Yes. I see that you're using an aero port, so that's going to limit you on the exact port area, but you can probably get away with using a little less port area with aero ports. Have you considered an L-ported box?
2 HDC3 18's
AQ2200D
i was making this box with aero port so i can cut the tube to find the best score thats why. do u have another suggestion skrilla? tx bro
In that case I'd go with a single 8", or two 6" aero port(s). It will be a little less than recommended port area, but it will be fine as long as it's a true flared aero port(s).
2 HDC3 18's
AQ2200D
  • Who's Online   0 Members, 0 Anonymous, 732 Guests (See full list)
