02 escape alt..wow
The easiest way or should I say the most convenient way to change the alternator is to:
1. Loosen lug nuts and wheel hub nut on right front tire.
2. Place the car on a jack stand on the right side.
3. Remove the tire.
4. Remove the plastic splash guard.
5. Remove the belt.
6. Pop the ball joint out.
7. Remove the lower control arm.
8. Take wheel hub nut off.
9. Remove drive axle carrier bearing nuts.
10. Remove entire axle as one unit.
11. Take wire and connector off alternator
12. Remove all three alternator bolts and push alternator off to the side.
13. Remove alternator mount bracket.
14. And finally remove alternator
Looks like this will be fun..anybody ever done a swap or even big 3 on 3.0 v6 have any tips or advice?
Youtube.com/J Hutch22
  • Who's Online   0 Members, 0 Anonymous, 906 Guests (See full list)
