Achaleon Posted February 24, 2013 Report Posted February 24, 2013 Trunk? I thought you were in a truck well yeah on the bedliner then Do you mean a blowthrough?
ElCompaTiny Posted February 24, 2013 Author Report Posted February 24, 2013 If you trow them In the truck with out cutting it Then yes all your going to here is the vibrations not the sound but isn't it the same thing when you throw the in the trunk of a car?
Guest Posted February 24, 2013 Report Posted February 24, 2013 If you trow them In the truck with out cutting it Then yes all your going to here is the vibrations not the sound but isn't it the same thing when you throw the in the trunk of a car? the trunk of a sedan can flow air into the cabin. a trucks cabin and bed are separate. unless you're going to cut a good 12-16 square feet of sheet metal out of your truck with a sawzall (aka blowthrough), then woofers in the bed are pointless.
ElCompaTiny Posted February 24, 2013 Author Report Posted February 24, 2013 Trunk? I thought you were in a truck well yeah on the bedliner then Do you mean a blowthrough? no blowthrough is a no no for me
Guest Posted February 24, 2013 Report Posted February 24, 2013 meaning, you wont hear jack shit. and plus it will get stolen really easily if you put them in the bed. edit: no blowthrough? then keep the subs in the cabin.
Achaleon Posted February 24, 2013 Report Posted February 24, 2013 Trunk? I thought you were in a truck well yeah on the bedliner then Do you mean a blowthrough? no blowthrough is a no no for me Putting an enclosure into the bed without a blow through is pointless. The air needs to be able to circulate into the cabin somehow Edit: Kranny beat me to it
Guest Posted February 24, 2013 Report Posted February 24, 2013 if you plan on fully powering 2 zv3's, you'll need a good grand in electrical work done. and thats not counting the amps.
ElCompaTiny Posted February 24, 2013 Author Report Posted February 24, 2013 If you trow them In the truck with out cutting it Then yes all your going to here is the vibrations not the sound but isn't it the same thing when you throw the in the trunk of a car? the trunk of a sedan can flow air into the cabin. a trucks cabin and bed are separate. unless you're going to cut a good 12-16 square feet of sheet metal out of your truck with a sawzall (aka blowthrough), then woofers in the bed are pointless. see well blow through reduces resale value does it not and is there enough room for a 18 in woofer if you do a blowthrough
Guest Posted February 24, 2013 Report Posted February 24, 2013 If you trow them In the truck with out cutting it Then yes all your going to here is the vibrations not the sound but isn't it the same thing when you throw the in the trunk of a car? the trunk of a sedan can flow air into the cabin. a trucks cabin and bed are separate. unless you're going to cut a good 12-16 square feet of sheet metal out of your truck with a sawzall (aka blowthrough), then woofers in the bed are pointless. see well blow through reduces resale value does it not and is there enough room for a 18 in woofer if you do a blowthrough why cant you just put woofers in the cabin like you're supposed to? edit: like, behind the front two seats.
