Coolwazabi Posted March 7, 2013 Report Share Posted March 7, 2013 Okay. I have 2 audiopipe 1800d's. A dual 1 ohm subwoofer. Can I wire each amp to 1 coil and run the amps at 1 ohm ? If so, whats it called ? And how would I do it ? So basically. 2 amps on each coil wanting to achieve possibly final ohm load of 2 ohm. Link to comment Share on other sites More sharing options...
kleinteich2 Posted March 14, 2013 Report Share Posted March 14, 2013 If you wire the coils in series and strap the amps you can run the final 2 ohm load to both amps and set all the settings from the master amp. A Whole lot easier and you wont have to try and gain match the amps. Link to comment Share on other sites More sharing options...
bassfreake Posted March 16, 2013 Report Share Posted March 16, 2013 If you wire the coils in series and strap the amps you can run the final 2 ohm load to both amps and set all the settings from the master amp. A Whole lot easier and you wont have to try and gain match the amps.the AP 1800 isn't strappable. Thanks I was pretty excited about the alt myself. kind of like a school girl, in a dress, on a swing. lol It's warming up enough that the donut-punching cyclist douchenozzles are getting their two wheeled fagmobiles out. My Build Log Link to comment Share on other sites More sharing options...
