Jessica Posted March 10, 2013 Report Posted March 10, 2013 ok, well you can search on the forums for "what volume headunits clip at" there is a thread full of different headunits and the max volume you can run on them. Setting gains without a proper tool is difficult, because of course, you need to verify you are giving the amp a clean signal first. I would just use a 40hz tone for your sub amp as i think tony said that is pretty much the industry standard. and use 1k for your mids amp if you have one. If you can't find you head unit in that thread i mentioned then you are just guessing again. I won't say "go buy a dd-1 right now". I have set gains by ears in the past on never blown anything up, but then again i am not you. No disrespect intended. If you want to be serious about this, then please by either an oscope or a dd-1 and do it right. Because like i said, without one of those you are only guessing. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
pintich Posted March 10, 2013 Author Report Posted March 10, 2013 ok, well you can search on the forums for "what volume headunits clip at" there is a thread full of different headunits and the max volume you can run on them. Setting gains without a proper tool is difficult, because of course, you need to verify you are giving the amp a clean signal first. I would just use a 40hz tone for your sub amp as i think tony said that is pretty much the industry standard. and use 1k for your mids amp if you have one. If you can't find you head unit in that thread i mentioned then you are just guessing again. I won't say "go buy a dd-1 right now". I have set gains by ears in the past on never blown anything up, but then again i am not you. No disrespect intended. If you want to be serious about this, then please by either an oscope or a dd-1 and do it right. Because like i said, without one of those you are only guessing. yeah i know that the HU start giving a bad signal at 49 so its clean at 48 a guy here on SMD had same as me and he had tested it and i have plans on getting a O-scope when i can get my hands on a good deal
Noel989 Posted March 10, 2013 Report Posted March 10, 2013 Gain is to. Match or not exceed the RCA voltage That's what a gain knob is Build Log - http://www.stevemead...-cruiser-el-pt/
