Cboeger Posted April 1, 2013 Report Posted April 1, 2013 I've got 2 questions, when I first installed my subs I put 1 of the 2ohm DVC speaker wires from the sub terminal to amp terminal (2 see if the subs still worked) and it wouldn't turn on ever no matter what I did until i spliced both +/- speaker wires from both subs together into the amp. Why did the subs not work until I did that? Was it because the amp realized the ohms load? Also, is it true some of the good amps have a capacitor already built into them for when bass hits?
Vito Basser Posted April 1, 2013 Report Posted April 1, 2013 I don't know why it would do that! Maybe you overlooked something? ALL amplifiers have capacitors inside them... Check out this post for interest. www.caraudio.com/forums/amplifiers/442855-sd12kd-inside-view-how-works.html
kylet1644 Posted April 3, 2013 Report Posted April 3, 2013 what amp ? just hooking up the 1 vc would have realized a 2 ohm load on the amp
