reg93f150 Posted April 16, 2013 Report Share Posted April 16, 2013 Did you use an accordion boot then seal the box to the boot and bed with foam? Sorry if you just said that, its still early and I'm tired And was your bed cover a hard top or soft? And was the box just resin or actual fiberglass matt? Thanks man!! ALL CREDIT TO XX1 FOR DC BANNER down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub Link to comment Share on other sites More sharing options...
COLTON94 Posted April 16, 2013 Author Report Share Posted April 16, 2013 Havnt done mine yet but iv been researcbing,acordian boot is a must bed cover is either one iv seen both used long as it keeps water out of the bed Link to comment Share on other sites More sharing options...
reg93f150 Posted April 17, 2013 Report Share Posted April 17, 2013 Yeah I knew accordion boot was a must.. And glasing box or bedliner a couple coats and bedliner is great But I think I know now to use the foam and seal the hole between box and bed and cab... ALL CREDIT TO XX1 FOR DC BANNER down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub Link to comment Share on other sites More sharing options...
