New Build- 2 15"
josh237
Hello all just wanted to see what your thoughts might be.
I am looking to put 2 15" Powerbass subs in the back of a 2005 Trailblazer and would like to know what you recommend for a box and what it should be tuned too. I want to get as much bass and as loud as possible out of it as I will be powering them with a Class D powerbass 1000 Watt stable at 1 ohm.
Looking for box idea's as I want to go ported and make it loud.
Power Handling
(RMS/Peak):
500/1000 watts
Nominal Impedance: Dual 4-ohm
Voice Coil Size: 2.5 in
Frequency Response: 27Hz - 450Hz
Sensitivity: 94dB
Motor Structure: 232 oz
Mounting Depth: 6.5 in
T/S Parameters
VC Impedance: 4 ohm + 4 ohm
Test Impedance: 1.6 ohms
Fs: 27 Hz
SD: 780 sqCM
Vas: 111 Ltr
Cms: 137.4 µM/N
Mms: 263.5 g
BL™: 11.3
Qms: 5.14
Qes: 0.54
Qts: 0.47
No: 0.36%
Spl: 94 dB
Xmax: 12 mm
Thanks for any help you may have for me.
Thanks
Josh
  • Who's Online   0 Members, 0 Anonymous, 1012 Guests (See full list)
