masterbusa2 Posted June 12, 2013 Report Share Posted June 12, 2013 Okay so been playign with WINISD, plannign on doing my first 6th order, the 2 15's Crossfire V.2 are already built and in the vehicle, my brother is tradingin his 4 15's for 2 Tantric HDD12's,,, anyways the 2 12's are going into a 6th order while the crossfires in brandons truck are in a vented tuned to 10^3 @27,,, in WinIsd it shows the 6th order will hit higher db's over a range at any given hz it hits higher than the crossfires, is this correct anyone toyed with the program? tuning for 6th is rear 10^3 @ 24,, Front 8^3 @45. sayign each gets correct power Link to comment Share on other sites More sharing options...
mrd6 Posted June 12, 2013 Report Share Posted June 12, 2013 Keep in mind winisd plots are for a parallel 6th...if you are building a quasi which is the more popular version it is going to be completely different.... My Build Log: http://www.stevemead...-sundown-power/ Team NorthWestSPL Link to comment Share on other sites More sharing options...
mrd6 Posted June 12, 2013 Report Share Posted June 12, 2013 and no you cannot just look at the plots and expect them to reflect which setup is going to be louder My Build Log: http://www.stevemead...-sundown-power/ Team NorthWestSPL Link to comment Share on other sites More sharing options...
masterbusa2 Posted June 12, 2013 Author Report Share Posted June 12, 2013 okay i guess i dont understand whats the difference between parrallel is which one is where first port ports into second side, or which is two sperate ports such as which is on a wall just two sets of ports or which is a huge port going into subs and a second port going to other chamber? Link to comment Share on other sites More sharing options...
masterbusa2 Posted June 12, 2013 Author Report Share Posted June 12, 2013 I was thinking two ports on a wall would be awesome, but if It does better on the other one so be it Link to comment Share on other sites More sharing options...
