jpsaudio Posted June 17, 2013 Report Share Posted June 17, 2013 got these 2 bb2400.1's on my build and for my electrical im running a mechman 270alt 2 kinetik hc2000's with a big 3 upgrade now my gains on the amp are not even turn up fa real but after about 10 mins of playing the amps get stuuuuuuuupid hot ill try to post a pic of the set up and the wire is ran straight from those batteries to the amp...now i dont have enough wire to get both amps on yet so its just one ampe running now on one sub because im puttin one one each but both subs are at a 1ohm load and both amps are 1ohm stable any ideas? Link to comment Share on other sites More sharing options...
bassinyerface Posted June 17, 2013 Report Share Posted June 17, 2013 Could be clipping or low voltage or a bad ground. Check voltage with an ohm meter and maybe get ur setup dd1'nd 2003 f150, 2 ab hd 15 on brutus 2400.1, kinetik batt, big 3, knu wire, image dynamics cxs 6.5 with ppi tweets, pioneer 1din and clarion eq. Link to comment Share on other sites More sharing options...
