Keveeno Posted July 1, 2013 Report Posted July 1, 2013 I have 1 run of 0 gauge running from front to back batteries (kinetic hc 2400's), I have the latest version of the aq3500 with dual inputs (running 0 gauge wire to the positives and negatives), need to know what fuse rating I need for the two runs off the batteries to the positive inputs on the amp. I'm assuming since the amp needs a 380 amp in line fuse, it just needs about a 200 amp fuse for each positive run into the amp correct?
russtezecustoms Posted July 1, 2013 Report Posted July 1, 2013 You fuse to what your wire is rated at. Are you running cca or ofc? How long are your runs? I just wish i had a funny sig.
Keveeno Posted July 1, 2013 Author Report Posted July 1, 2013 You fuse to what your wire is rated at. Are you running cca or ofc? How long are your runs?I'm sorry I don't know what cca and ofc stands for. Using knukonceptz kolossus fleks 0 gauge wiring for both positive and negative runs. The wire can handle a 300 amp fuse rating. The runs are fairly short cause the back batteries sit next to the amp so I would say the runs will be about 2 to 3 feet. Maybe even shorter.
kl0wn Posted July 1, 2013 Report Posted July 1, 2013 300a fuses 06 Mini Cooper S Sundown, SoundQubed Cadence, XS Power 151s Sealed 155s Outlaw Windshield @ 37hz
russtezecustoms Posted July 1, 2013 Report Posted July 1, 2013 Ofc- oxygen free copper. Cca- copper coated aluminum. And yes if short runs fuse to wire rating maby a little less. After all your trying to protect your wire with those fuses, the amp has its own protection. I just wish i had a funny sig.
