leachmike Posted August 21, 2013 Report Posted August 21, 2013 hello i have a 97 suburban that i would like to build a box for... the bigger the better just i would like them and the port to fire upwards...i have 2 kicker comp VR12s and each are powered by alpine MRP-500 (1 amp per sub)...@ 2 ohm .....i mostly listen to rap and rock ...please help me with box cut...i have built lots of boxs before but have just guessed on dimensions ..please help me do this one right..thanks in advance
jarrius Posted August 21, 2013 Report Posted August 21, 2013 No one can help you unless you give your max hight max width and max length. 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
leachmike Posted August 22, 2013 Author Report Posted August 22, 2013 ok ....box dimensions that will fit H=24" L=16" W=36" with a few inches either way for wiggle room
jarrius Posted August 22, 2013 Report Posted August 22, 2013 Now according to what I was reading about te comps (never used them) factory says about 2cubes for 1 so I would say 4 cubes for 2 of them tuned to about 35hz will sound good. Also since your running one amp per sub you need to make sure you gain match the amps so one sub is not getting more power then the other. 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
